View tunnel interfaces to verify the current configuration and operational status of IPv6 tunnels.
  1. Enter Privileged EXEC mode:
    enable
  2. Show IPv6 tunnel information:
    show ipv6 tunnel [<1–2000>] [detail] [local {A.B.C.D}] [remote {A.B.C.D}]
Switch:1#show ipv6 tunnel detail
                          Tunnel Interface Information
ID         LOCAL ADDRESS   REMOTE ADDRESS  OPER STATUS TYPE
2          211.1.55.2      44.1.55.1       active      manual
1          211.1.55.2      44.1.55.43      active      manual
210        211.1.60.2      47.1.60.1       active      manual
3 out of 3 Total number of entries displayed.
                              Address Information
IPV6 ADDRESS/PREFIX LENGTH                   TYPE    ORIGIN    STATUS
43:210:0:0:0:0:0:2/64                        UNICAST MANUAL    PREFERRED
fe80:0:0:0:0:0:d301:3702/64                  UNICAST LINKLAYER PREFERRED
44:211:0:0:0:0:0:2/64                        UNICAST MANUAL    PREFERRED
Variable definitions
Use the data in the following table to use the show ipv6 tunnel command.
Variable
Value
<1–2000>
Shows information for a specific tunnel ID.
detail
Shows detailed address information for the tunnel.
local {A.B.C.D}
Shows information for a specific local address (the local endpoint of the tunnel).
remote {A.B.C.D}
Shows information for a specific remote address (the remote endpoint of the tunnel).
